Posted on 08-04-2015 06:25 AM
Hello all,
Problem explanation:
We would like to create a local images replication point on series of 250GB ssd thunderbolt drives in order to deploy a thin image onto approx 3000 macbook air's [sic]. - 5 drives imaging 5 mac's at a time. The problem is our main distribution point exceeds the size of our ssd drives.
Question:
Is it possible to manually copy to the external thunderbolt drive only the images (or compiled image and scripts) that we need (into the appropriate replication point folder structure of course) and deploy the thin image in that fashion?
Thanks in advance for your help.
LPS
Posted on 08-04-2015 06:30 AM
you can replicate whatever you choose, and as long as you only use what you have everything will work well. I have "build" Macs that have the stuff to do imaging only in their local copy of CasperShare/Packages and imaging is much faster than over the network plus I do not have to have the full 80GB of software copied local that the entire CasperShare has.
Posted on 08-05-2015 04:10 AM
Absolutely not a problem. I have a variety of drive sizes that I use for imaging - the smallest is 64GB. I can't run my dual-boot images off of it, but I have plenty of space for my OS X only images.
A couple of things to be aware of:
You may want to consider investing in some additional drives. I use everything from a thunderbolt SSD to a usb memory stick. The thunderbolt drives are faster, but I can buy a 4-6 USB drives for the cost of 1 Thunderbolt SSD. One person can keep up with 8-10 drives in a workflow that does not involve unboxing. Per person we can do between 175-225 devices in an 8-hour day with this setup.
