Posted on β06-27-2018 04:04 AM
Hello and thank you for taking a moment to look at this. I will try and keep it short and sweet!
I am running Jamf 10.4 and am having issues getting Patch Management to display any software titles.
When I go into Patch Management > New I get the following error...
(A connection error occurred while attempting to download software titles from this source.)
Everything else is working as far s I can tell. However, I have not used this feature before, only glanced once or twice in the past and the software at one point did populate. Am I missing something easy here or has anyone seen this before at all? I appreciate any and all suggestions, thank you!
Solved! Go to Solution.
Posted on β09-05-2018 02:55 AM
I forgot to close this out and mark it answered. For my case, our IT Security was blocking a few extra things from Apple. Once they made a change it started working again. This unfortunately took a number of attempts to get them to really look at the traffic. Thank you all for your assistance!
Posted on β06-27-2018 09:25 AM
Yep, having the same thing here.
Posted on β06-28-2018 07:32 AM
Not that it helps, but I am glad to see I am not the only one with this annoying issue. Hard to believe that there is little information on it. That or I am just wording my search criteria pretty badly.
Posted on β06-28-2018 11:25 AM
Sorry this is happening, @TechnoKhan and @Jmazzuca182. Have you had a chance to contact Jamf Support for troubleshooting?
Posted on β06-28-2018 11:33 AM
yes, but not getting anywhere on it.
Posted on β07-06-2018 03:07 PM
Took me a while to figure this one out as well (running our Jamf server on Win 2012). It turns out, for us, it was the Java options within Tomcat.
Take a look at this post by @bradtchapman. This helped me resolve our issue.
The other thing to look out for is making sure your networking team has https://jamf-patch.jamfcloud.com/ whitelisted as detailed here.
https://www.jamf.com/jamf-nation/articles/34/network-ports-used-by-jamf-pro
