Posted on 01-17-2017 06:55 AM
In Self Service, I want to publish a licensed application for specific users to be able to install, but only to one specific computer. Same users should also be able to reinstall the app on the same computer.
How should I put this together using scope and execution frequency? Is this possible at all?
Hope you understand what I'm trying to achieve here...
Posted on 01-17-2017 07:45 AM
So you want a user to login to self service on a specific machine and see the policy to install? I guess I would scope the policy to the specific computer, then put the user's name in 'Limitations'. Then, when that user logs in on that machine, the policy is available.
Posted on 01-18-2017 12:05 AM
First of all, I seem to have double posted for which I'm very sorry.
Thanks for a quick answer!
Later on yesterday I took another peek at it. By limitations I assume you mean "Client-Side Limitations" under Options/General, because I can only see Network Segments and iBeacons under Scope/Limitations. I have tried ticking the box "limit to JSS-assigned user" and that seems to have solved my issue.
