Possible to Add a 3rd Party Network Adapter via Script?
Hello,
Firstly- please excuse my noobishness. I recently got CCT'd, and I'm mostly a lurker so not used to posting on forums in general.
That in mind:
Our institution has decided that, as a fallback, all administrative staff should be able to connect to our network via Ethernet. With that in mind we just bought a whole bunch of USB3 -> Ethernet adapters (we mostly run MacBook Airs).
What I'm wondering: is it possible to get the properly configured adapter settings from one laptop and add it to all administrator laptops via a script? Or something of similar effect? I want to do a touchless install/configuration.
Any suggestions are appreciated. Thanks in advance!
The adapter:
- Linksys USB3GIGv1
- Requires a *.pkg install................................................................done
- Requires usual 'Network Preferences' configuration....................TBD (what I'm asking about)
Best answer by joshuasee
If you can run a script while the NIC to be deployed is plugged into the computer and network, you might be able to get away with with just creating a new location and auto populating it.
/bin/echo "Refreshing network services."
/usr/sbin/networksetup -detectnewhardware
/usr/sbin/networksetup -createlocation Default populate
/usr/sbin/networksetup -switchtolocation Default
/usr/sbin/networksetup -deletelocation Automatic
# Delay and show countdown while letting network regain an IP.
/bin/echo -n "Waiting for network to reconnect...5";
/bin/sleep 1;
/bin/echo -n "...4";
/bin/sleep 1;
/bin/echo -n "...3";
/bin/sleep 1;
/bin/echo -n "...2";
/bin/sleep 1;
/bin/echo "...1";
/bin/sleep 1;
/bin/echo "
Available network services in order of priority:";
/usr/sbin/networksetup -listnetworkserviceorder
  • November 2, 2015
/bin/sleep 1;
/bin/sleep 1;
/bin/sleep 1;
/bin/sleep 1;
/bin/echo "...1";
/bin/sleep 1;
/bin/echo "
  • November 2, 2015
joshuasee,
I'll give it a try and get back to you!
EDIT:
Rockin'! It worked.
I ended-up using it with a login hook, so need for the echos (for me).
For anyone else interested, these are the steps I took:
  1. Created policy to install driver via Self Service (requires reboot)
  2. Created policy using above script which is triggered by login. Hardware is powered and plugged-in.
  3. Magic.
Thanks again, joshuasee!
bpavlov
  • November 2, 2015
Why would you need to create a new location? Why not just detect the new hardware?
Cookie policy
Cookie settings
