Posted on
06-04-2024
07:28 AM
- last edited
2 weeks ago
by
kh-richa_mig
https://ideas.fabric.microsoft.com/ideas/idea/?ideaid=1d1acbef-5e21-ef11-8ee8-000d3a7c8d70
Posted on 06-12-2024 07:16 PM
Take a look at this; I am currently in the process of changing my dashboard to use this method, which requires some massaging of data but will provide you with greater scope on the data you can pull from Jamf.
Posted on 08-06-2024 05:32 PM
I am not following you on the setting the ClientID and ClientSecret parameters. Should they both be filled with the secret code? I got this when I put the secret in both parameters... "Expression.Error: The import paramClientID matches no exports. Did you miss a module reference?"
Posted on 08-06-2024 05:59 PM
Hi, just a disclaimer this is not an article that I published but one that helped get things going again. But for you question the "paramClientID" PowerBI variable should match your API account in Jamf ClientID and the paramClientSecret should match your Jamf API Client Secret.
Posted on 08-08-2024 12:38 PM
