Prefill login info for Netflix and Plex
rbart
New Contributor
We have a couple hundred Apple TV's that use the same logon info for Netflix and Plex. The app installs but I have not been able to figure out how to prefill the username and password.
Is Jamfcloud capable of pushing out login info for these apps?
2 REPLIES 2
mainelysteve
Valued Contributor II
The apps themselves need to support Managed App Configuration and neither do I believe. I'd say Netflix will be a hard pass if you ask them for it. Plex may be willing if you send them a feature request.
facepalmbear
New Contributor
I have the same dilemma. I am setting up iPads with Netflix and Hulu for patient use, and they are going to be wiped either nightly or between patients (yet to be determined) using Jamf Reset. We are using managed Gmail accounts for streaming, and the nurses/staff are concerned about having to spend time logging in with the credentials each time.
I tried calling Netflix, but asking if the app supports Managed App Configuration did not go anywhere.
Has anyone else heard any differently?
