Prevent iTunes from automatically Syncing - Mojave
Wondering if anyone has run into this issue. We have a few lab machines that are using iPads to digitize using AstroPad. They are tethered to the Mac via USB. Each user has iTunes open to synch the iPad. Wondering if there's a way to disable this functionality. I found some documents referencing modifying com.apple.iTunesHelper.plist but that file doesn't appear to exist any more. Some others reference removing the iTunesHelper.app from within the package but that is sip protected now.
We are running jamf 10.11.1 and 10.14.6 for Mojave
Be the first to reply!
Cookie policy
Cookie settings
