Printer Admin - LP Admin - Group?
bwiessner
Contributor II
Hello everyone,
Trying to give staff who are not local admins rights to add and remove printers. I am getting an error when this runs - any ideas or info would be appreciated.
Command:
sudo dseditgroup -o edit -t group -a "ISDXXXDistrictSecurity GroupsAll Staff" _lpadmin
Output of command:
Executing Offline Policy Printer Admin Access...
Running command sudo dseditgroup -o edit -t group -a "ISDXXXAll Staff" _lpadmin...
Result of command:
Group not found.
1 REPLY 1
mscottblake
Valued Contributor
@bwiessne Try that same command without the underscore:
dseditgroup -o edit -t group -a "ISDXXXDistrictSecurity GroupsAll Staff" lpadmin
Also, remember, policies run as root, so no need to sudo if you're using Casper tools.
