We're testing 10.6 on a few machines. The version of Parallels 5 that we had did not seem to want to work with 10.6. I downloaded the latest version from Parallels 5.0.9344.55874. I used the procedure provided by jamf (extracting "install.mpkg"). However, each time I receive this in the error log:
Event log from the policy:
/usr/sbin/jamf is version 7.2
Executing Policy Install Parallels...
Downloading BOM for Parallels 5.0 Installer.mpkg...
Downloading Components of http://xxx.xx.xx.xxx:80/CasperShare/Packages//Parallels<http://xxx.xx.xx.xxx:80/CasperShare/Packages/Parallels> 5.0 Installer.mpkg...
Installing Parallels 5.0 Installer (9344.55874).mpkg...
Installation failed. The installer reported: Parallels CPU Check Tool
CPU Vendor: Intel
Hardware Virtualization: PRESENTED (VT-x)
Summary: Your CPU can run Virtual Machines
usage: dirname path
usage: dirname path
usage: dirname path
usage: dirname path
usage: dirname path
usage: dirname path
installer: Ignoring invalid resource fork length for /var/folders/zz/zzzivhrRnAmviuee+++++/-Tmp-/PKInstallSandbox-tmp/Root//Applications/Parallels
installer: Package name is Parallels Desktop 5 for Mac
installer: Installing at base path /
installer: The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
Running Recon...
Gathering Application Usage Information...
Finding Extension Attributes...
I then tried capturing this using composer but then I receive the error that "parallels cannot start the service...". None of these problems occur on 10.5, only my 10.6 test machines.
Anyone have any suggestions?
Noah Swanson
Macintosh Development/Support
Enterprise Desktop Services
Phone: 309-765-3153
SwansonNoah at johndeere.com
