Problems rebooting after running a policy?
Not applicable
I've seen this a couple times now, thought the first must've been my mistake
for not checking the box, but after seeing it a couple more times I'm
wondering whats going on.
3 REPLIES 3
Not applicable
run software updates, update the inventory.
The software package is marked as =B3requires reboot=B2 in Casper Admin, so on
the Reboot tab I=B9ve left selected =B3Reboot if SWU or Package requires.=B2 With
this selected, the policy runs fine, tells me the install was successful,
but then I don=B9t get any sort of reboot prompt on the machine.
I=B9ve also told Casper Remote to reboot the machine after running the policy
and the install is successful, but I still get no reboot prompt on the
machine afterward.
Any suggestions? Something I=B9m missing?
Thanks,
Bob
--B_3348646022_1289676
Content-type: text/html; charset="ISO-8859-1"
Content-transfer-encoding: quoted-printable
Not applicable
ware, run software updates, update the inventory.<BR>
<BR>
The software package is marked as &#8220;requires reboot&#8221; in Casper A
dmin, so on the Reboot tab I&#8217;ve left selected &#8220;Reboot if SWU or Package requires.&#8221; With this selected, the policy runs fine, tells me the install was successful, but then I don&#8217;t get any sort of reboot pr
ompt on the machine.<BR>
<BR>
I&#8217;ve also told Casper Remote to reboot the machine after running the policy, and the install is successful, but I still get no reboot prompt on t
he machine afterward.<BR>
<BR>
Any suggestions? Something I&#8217;m missing?<BR>
<BR>
Thanks,<BR>
Bob</SPAN></FONT>
</BODY>
</HTML>
--B_3348646022_1289676--
Not applicable
I used to see this. For me, it was the result of checking the box to "Enforce Management Framework" in the policy. disabling this made the effect more consistent for me. Still, if another jamf process or policy is running, it will delay the reboot until its done.
Regards,
--missing content--
The software package is marked as =93requires reboot=94 in Casper Admin, so on the Reboot tab I=92ve left selected =93Reboot if SWU or Package require
s.=94 With this selected, the policy runs fine, tells me the install was su
ccessful, but then I don=92t get any sort of reboot prompt on the machine.
I=92ve also told Casper Remote to reboot the machine after running the poli
cy, and the install is successful, but I still get no reboot prompt on the machine afterward.
Any suggestions? Something I=92m missing?
Thanks,
Bob
--missing content--
, run software updates, update the inventory.<br>
<br>
ccessful, but then I don=92t get any sort of reboot prompt on the machine.<br>
<br>
cy, and the install is successful, but I still get no reboot prompt on the machine afterward.<br>
<br>
Any suggestions? Something I=92m missing?<br>
<br>
Thanks,<br>
Bob</span></font> </div>
