Problems with VPP (maybe since Update to Jamf Pro 11.3.2)
  • April 11, 2024
  • 52 views
Yesterday I noticed that I am unable to download VPP Apps via Self Service. My users get an instant error when they try to install a VPP App.
I did some further investigation an I found some more strange behaviour:
#1 Trying to add a new VPP App in Jamf pro. Computer -> Mac Apps -> Add new App -> searching is ok and it will list me items. But when I try to add an App it will result in a timeout
#2 I tried to renew the VPP token. When I try to upload it in Jamf Pro Settings I get 500 error.
Any ideas?
Kind regards
Marc
  • April 12, 2024
Are you Jamf Cloud, or OnPrem?
I'm wondering if it's worth raising a case to Jamf - they might see something in your logs that require a server restart to fix a problem.
I had an issue in my sandbox where one App wasn't pulling through - Jamf advised me is was because the ADCS connector errors (we were trying to get it up and running) were causing performance issues.
Have you recently changed your ABM/ASM password? I know that requires a token renewal, but you say you've tried that and it fails.
If you're on-prem, you could restart the servers yourself if you're happy to do that without Jamf Support advising it, but JamfCloud - they need to do it
  • April 15, 2024
Thanks for the response.
Yes, I am OnPrem and I already restarted the server.
We did not change the Password on ABM. and renewal of Token doesn't work (as stated in my first post)
I will create a Jamf Case.
Kind regards
Marc
