Posted on β02-05-2015 10:21 AM
Hello!
I am super new to using Casper and am about to begin rolling out the program. From all I've learned, no one's seemed to touch on the subject...
Is there a way to run a report on data for each iPad that includes the iPad name, serial number, and MAC Address?
Posted on β02-05-2015 10:25 AM
Thats all available in the advanced search options in the JSS.
Create an advanced search and either set it to display in the web page, or download as a CSV.
You can save the search so you can run it again in the future.
