Posted on β02-23-2007 01:11 PM
I have quite a few machines whose serial number can't be read from software -- it's a condition that typically results from a logic board replacement. When Recon interacts with a machine in this condition, Recon fills the Serial Number field in the JSS in one of a few different ways, depending on the make/model of the machine. For example, one Apple iMac Intel (Early 2006 Core Duo) appears to have the serial number "SystemSerialNumb" in my JSS.
When I first noticed these non-useful serial number entries, I went through and manually keyed the correct serial numbers into the JSS. Then I noticed that the next time I ran Recon, my manual entries were overwritten with entries like "SystemSerialNumb" again.
I first encountered this problem back in Casper 3.21. I've since upgraded the JSS to 4.1, but I haven't chased away the problem. Any suggestions?
Brandon White
System Administrator
Tekserve
Posted on β02-23-2007 03:07 PM
This sounds like it would need to be a feature request. I would think that
On 2/23/07 3:11 PM, "Brandon White" <bhwhite at tekserve.com> wrote:
logically a serial number would never need to be changed for a system after
having been input for the first time (unless you've changed the logic
board).
A simple "Update system serial number field only if empty" preference might
do the trick. This would allow you to keep your updated information.
bill
William M. Smith, Technical Analyst
Digital Information Systems Support
Merrill Communications, LLC
(651) 632-1492
Posted on β02-23-2007 03:27 PM
Hi everyone...
What Bill suggested is already implemented, but for a slightly different scenario. We haven't seen the "SystemSerialNumb" reported from a replaced logic board. Until now, we've only seen a blank entry or a tab character. We will add a check for "SystemSerialNumb" to ensure that it is handled properly. If anybody sees another scenario, please let us know!
regards,
zach
Posted on β02-23-2007 04:09 PM
We have a few that report as the following:
On 2/23/07 5:27 PM, "Zach Halmstad" <zach at jamfsoftware.com> wrote:
OS Model SN Speed
Mac OS X 10.3.7 iMac 55 233 MHz
Mac OS X 10.3.7 Power Mac G3 (Blue and White) 55 350 MHz
Mac OS X 10.4.7 Power Mac G3 (Blue and White) 0 450 MHz
Mac OS X 10.4.7 Power Mac G5 0 2.7 GHz
Mac OS X 10.4.7 Power Macintosh G5 (Late 2005) 0 2.5 GHz
On a side note...
What would be super duper cool is if you could implement the feature of this
website <http://www.chipmunk.nl/klantenservice/applemodel.html> into the
JSS. Plug in any Mac serial number and this site will give the following
feedback:
aantalip: 1
Serial number: XB3074BCN1W
Name: Power Macintosh G4 (FireWire 800)
Model: Mxxxx PowerMac G4 1.0GHz
Bus speed: 133MHz
Factory: XB (ElkGrove/Sacramento, California)
URL: Technical specifications by apple-history.com code_to_number: 4BC -
UV20232GLLN
Model introduced: 2003
Production year: 2003
Production week: 07 (February)
All the production information is coded into the serial number. I find
especially helpful the manufacture date. I can justify to a manager to
replace his Mac when I can say something like "Your current Mac will be
seven years old in March."
bill
(651) 632-1492
