Recon - v9.82 via About Recon but v9.81 when using Get Info
allencreech
New Contributor II
Just downloaded Casper 9.82 from my assets and ran Recon. Noticing that Recon is showing "Recon 9.82 for ...." in the application, and "Version 9.82" when using Recon->About Recon but Apple's "Get Info" shows 9.81.
No biggie - just wanted to let JAMF know.acfc052b3b29473690b79e486163ece9
2 REPLIES 2
lunddal
Contributor
OS X seems to cache the "Get Info" info, and updated apps can have old info for a little while.
Look
Valued Contributor III
As @lunddal said, this is exactly what happens. You will find in a little while it just magically starts showing the right version.
It pretty much always happens if you drop a file into the exact same location as a previous file of the same name.
Restart usually fixes it if your in a hurry to see if it's actually changed.
