I am trying to find a way to reformat a large number of intel drives that were set up with APM formatting while they go through the imaging process. Anybody else run into this one in the past. I have played around trying to get diskutil to do it but no luck changing the underlying formatting.
reformat apm drive to guid via script in casper
Best answer by jarednichols
You want something like:
diskutil partitionDisk /dev/disk0 1 GPTFormat jhfs+ "Macintosh HD" 100%
One thing that sticks out is that you say "change the underlying formatting." You do realize the disk must be wiped to change the partition table format, correct?
