Removing System Extensions
  • November 4, 2021
  • 0 replies
  • 21 views
So I have the need to remove a system extension that is installed on over 200 devices.
For what I read so far the solution is to disable SIP and run the systemextensionsctl uninstall  command. This is not a solution for me since most of the computers are not physically accessible to disable SIP. Is there any workaround for this on Jamf?  Disabling SIP looks impossible with Jamf, but maybe there is a way to uninstall the system extensions.
Also, the users don't have admin rights
Any help is appreciated 🙂
