Script Exit Code
  • February 20, 2015
  • 10 views
msample
  • 65 replies
Does the script exit code: 0 mean that the policy was not applied? And does the script exit code: 1 mean that the policy was applied?
Best answer by rderewianko
Exit 0 = Script Executed successfully Exit 1 = Script Executed unsuccessfully (there we're errors or problems)
  • 486 replies
  • February 20, 2015
  • 7886 replies
  • February 20, 2015
You may want to look up some guides on bash script exit codes, like here: http://steve-parker.org/sh/exitcodes.shtml
There are others too.
Exit code 0 almost always means it was successful. Anything other than 0 means it failed.
msample
  • 65 replies
  • February 20, 2015
Thanks, Ross...thanks, Mike. It's just the reverse of what I had thought.
Cookie policy
Cookie settings
