So we have had an issue with our M$ Messenger and finally got a fix for
it today. The downside is that it requires a bit of terminal
interaction. What would be the best way to go through this as we have
to deploy to about 500 machines...
* Save attached file without the .TXT extension.
* Open Keychain Access from Applications/Utilities.
* Go to File->Add Keychain.
* At this point you are in ~/Library/Keychains. Browse to
/System/Library/Keychains and add X509Anchors.
* Right-click the newly added keychain and unlock it.
* Open Terminal from Applications/Utilities.
* sudo chmod -R 777 /System/Library/Keychains
* Double-click the certificate and add it to the X509Anchors
keychain.
* Go back to your terminal window. If you closed it, just open
another.
* sudo chmod 755 /System/Library/Keychains (no -R this time as
the files inside have different permissions)
* sudo chmod 644 /System/Library/Keychains/*
* Close Terminal and Keychain Access.
John Wojda
Lead System Engineer, DEI & Mobility
3333 Beverly Rd. B2-338B
Hoffman Estates, IL 60179
Phone: (847)286-7855
Page: (224)532.3447
Team Lead DEI: Matt Beiriger
<mailto:mbeirig at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.>
Team Lead Mobility: Chris
<mailto:cstaana at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.> Sta
Ana
Mac Tip/Tricks/Self Service & Support
<http://bit.ly/gMa7TB>
"Any time you choose to be inflexible in your approach to an
unpredictable project you are already building failure into your plan"
