script help!
Cem
Valued Contributor
I am getting this error for the script below – any ideas?:
attribute status: eDSAttributeValueNotFound
DS Error: -14143 (eDSAttributeValueNotFound)
/private/tmp/LionADsearchPathFix3.sh: line 15: syntax error near unexpected token `else' /private/tmp/LionADsearchPathFix3.sh: line 15: `else '
dsconfigad -alldomains disable
csp="dscl /Search -read / CSPSearchPath | grep /Active"
if dscl /Search -read / CSPSearchPath | grep /Active > /dev/null
then
/usr/bin/dscl /Search -change / CSPSearchPath "$csp" "/Active Directory/tree/domain.com"
/usr/bin/dscl /Search/Contacts -change / CSPSearchPath "$csp" "/Active Directory/tree/domain.com"
dscl /Search -append / CSPSearchPath  "/Active Directory/tree/domain.com"
dscl /Search -create / SearchPolicy dsAttrTypeStandard:CSPSearchPath
dscl /Search/Contacts -append / CSPSearchPath  "/Active Directory/tree/domain.com"
dscl /Search/Contacts -create / SearchPolicy dsAttrTypeStandard:CSPSearchPath
3 REPLIES 3
nessts
Valued Contributor II
the fi on the line before the else is likely your problem.
Cem
Valued Contributor
that was the white space issue after reading dscl. But this worked better at the end... so no need to fix that ;)
rm /Library/Preferences/OpenDirectory/Configurations/Contacts.plist
rm /Library/Preferences/OpenDirectory/Configurations/Search.plist
killall opendirectoryd
dscl /Active Directory/tree/domain.com -read /Users/testuser > /dev/null
    dscl /Search -create / SearchPolicy CSPSearchPath
    dscl /Search/Contacts -create / SearchPolicy CSPSearchPath
funny thing is that if I didn't do;
then it wouldn't work??? strange...
Cem
Valued Contributor
wait ;
need to put sleep command too...
after
sleep 5
