Hey there,
Sorry - The title should read "EXIT" code, not Error code.
I have a script policy that uninstalls a specific program.
The script when ran manually from my Desktop works properly, and uninstalls the program in question.
When I run the Policy, it mentions that the script ran correct (Exit Code = 0), but the program doesn't actually get uninstalled...
Here is what the output is from Terminal when I run "sudo jamf policy" :
Executing Policy Script - Remove ScreenConnect Remote Agent Running script ScreenConnect Remote Agent Removal... Script exit code: 0 Script result: Checking for patches... No patch policies were found. Running Recon... Retrieving inventory preferences from https://scalar.jamfcloud.com/... Finding extension attributes... Locating package receipts... Locating accounts...
Any idea why the script would work and uninstall when ran manually, but not uninstall when ran from Jamf ?
