Script to set preferred wifi--works from Remote but not Self Service
  • March 27, 2014
  • 11 replies
  • 60 views
I've written a script that removes our corporate WiFi network and then re-adds it as the top preferred network.
When I run the script on a client through Casper Remote, it works as expected.
When I run it as a policy through Self Service, I get asked to allow networksetup (the binary that is doing the work in the script) to access the keychain item for the WiFi network. Any help? The script is below.
# Script for to set the preferred wifi SSID and/or remove an unwanted SSID
# $4 is the SSID you want to make the preferred network.
# $5 is the SSID you want to remove from the list of preferred networks
# These variables are passed in by Casper--set them in Casper Remote or in policy settings, depending on how you're deploying the script
# Set the SSID specified in $4 as the preferred network by removing it and re-adding it
if [ -z "$4" ]
then
echo "No preferred SSID has been passed into the script, skipping this step..."
echo "Setting $4 as the preferred WiFi network..."
wifi=`networksetup -listallhardwareports | awk '/Hardware Port: Wi-Fi/,/Ethernet/' | awk 'NR==2' | cut -d " " -f 2`
/usr/sbin/networksetup -removepreferredwirelessnetwork $wifi $4
/usr/sbin/networksetup -addpreferredwirelessnetworkatindex $wifi $4 0 WPA2E NONE
# Delete the SSID specified in $5
if [ -z "$5" ]
then
echo "No SSID is set to be deleted"
ssidToDelete=`networksetup -listpreferredwirelessnetworks $wifi | grep $5`
    if [ -z "$ssidToDelete" ]
    then
    echo "$5 isn't set up on this computer"
    /usr/sbin/networksetup -removepreferredwirelessnetwork $wifi $ssidToDelete
  • March 28, 2014
Hmm... maybe no one saw this since I posted late last night? Hoping the day shift has some insights...
  • March 28, 2014
my guess is that you need to use the security command to unlock the system keychain, but just a guess.
  • March 28, 2014
@stevehahn Since you're using networksetup multiple times in the script do you have any indication where in the script its getting stopped with the authentication request? Can you add some echo lines throughout or have the script send stdout and stderr to a log file somewhere so you can see that?
I've done some similar things with networksetup recently in scripts and can't say I've had the issue of it needing admin credentials as long as the script is running as root or with sudo.
  • March 28, 2014
I added this to the script right before it adds the preferred network back in:
security unlock-keychain -u /Library/Keychains/System.keychain
No luck. :(
  • March 28, 2014
external image link
The dialog suggests to me that maybe it's not the System keychain it's after, maybe the user's keychain...?
  • March 28, 2014
@mm2270 Yes, I've run the script locally and it's getting stopped here:
So the only time I don't get the error is when deploying through remote; if I run the script locally or through Self Service I get the access request.
  • March 28, 2014
Are there any spaces in the network name? I see the $4 is not quoted in your command. Maybe its getting tripped up because of a space or other character in it that would benefit from being enclosed in quotes?
Edit: Never mind the comment on the index position. I may have been thinking of something else.
Also, since you said it works from Remote as is, just not from SS, etc. its likely not the quotes issue.
  • March 28, 2014
Hey guys;
does this work better than a mobile config,or in conjunction with a mobile config
LS
  • June 25, 2014
Hey i was trying to script out the same type of sequence to just install a network, did you ever find a fix for this issue?
@stevehahn
  • July 29, 2014
I'm having the same issue when run locally and the post image script errors out not setting the Wi-Fi on 10.9.4..
  • July 15, 2016
Bringing life back into an old thread, was a fix ever found for this?
