Scripting help
We are pretty new to Jamf and still trying to understand the scripting.  We have a renamecomputer script that we got as part of our onboarding for computers.  Was working great till we started sending in the department on the user from Okta.  So now the naming is off.  I am pretty good at Powershell and C#, but bash scripts I am struggling with.  Is there way in a bash script to look up a department value in like a switch statement?
example if the department is "IT", then can you do something like this?
switch (department)
case "irs":
     value = 123
case "IT":
     value = 987
Any help or pointers to reference links would be great.  I am not sure what the bash term would be to do that so if I can get someone to help with that, might be able to get this figured out.
Best answer by mm2270
BTW, there is in fact such a thing in bash/zsh as a case statement, similar to what you posted above.
Example:
department="somevalue" case "$department" in irs) value="123" ;; IT) value="987" ;; esac
 You can add as many of these to the case statement as you need to.
  • 7886 replies
  • April 9, 2024
Hi there! It might help us if you posted the existing script you're using right now, just for reference.
I guess I'm not quite understanding how including department information from Okta is causing the rename script to not work as expected, but that could be because I don't use Okta, so I'm not that familiar with it.
  • 7886 replies
  • April 9, 2024
Example:
  • April 10, 2024
*Removed
  • April 10, 2024
Example:
That is exactly what I was looking for.  Thank you!
  • 34 replies
  • April 10, 2024
mlinkey wrote:
*Removed
Just sent you a PM - not sure if you have notifications set up, so posting a message here too
Cookie policy
Cookie settings
