Scripts for TimeMachine backups over SMB with AutoMounting on reboot.
  • Nov 14, 2022 4:08 PM UTC
  • 188 views
So, we had an interesting task of getting Time Machine to work over SMB and making it all scripted for zero touch and automated for remounting on reboots.
We have a working script! And we are sharing it with y'all.
How does it work?
"Autofs" is the key to making this all work.
and crontab for activating the mounts on reboot or disconnect/reconnect/
We use computer serials as usernames for users SMB mounts to a Time Machine share. and each computer has their own folder by serial in the share, A Sparebundle file is the TimeMachine backup destination in each folder per computer.
We run the script via a policy per computer with parameters filled for the script.
notes:
one odd behavior, if the script fails, a reboot helps get it working, not sure why yet,
Requirements:
Terminal PPPC, with full disk access,
Crontab PPPC with full disk access.
script:
#/bin/bash # INPUT PARAMETERS: # password # size # server #---------------------------------------------- # o pipefail # -E = err trap inherited by hsell functions # -e = exit immediately if a command exists with non-zero # -u = treat unset variables as an error when substituting set -xEe password=$4 size=$5 server=$6 local_volume=/System/Volumes/Data/TM serialnum=`system_profiler SPHardwareDataType | grep Serial | sed -e 's/.*: \\(.*\\)/\\1/g'` remotedest=//TM-$serialnum:$password@$server:/TM sparsebundlevolumename=TimeMachine sparsebundlemountpath=/System/Volumes/Data/$sparsebundlevolumename timemachinedestination=/Volumes/$sparsebundlevolumename backupdir=$local_volume/$serialnum sparsebundle=$size.sparsebundle sparsebundlefull=$backupdir/$sparsebundle touch_volumes_script_full_path=/usr/local/bin/blueflame47_touch_tm_mounts.sh echo "Password is: $password" echo "Size is: $size" echo "remote destination is: $remotedest" echo "Computers serial number is: $serialnum" echo "Remote destination is: $remotedest" echo "Sparse bundle volume name is: $sparsebundlevolumename" echo "Sparse bundle mount path is: $sparsebundlemountpath" echo "Time machine destination is: $timemachinedestination" echo "Backup dir is: $backupdir" echo "Sparse bundle file name is: $sparsebundle" echo "Sparse Bundle full path is: $sparsebundlefull" # create the auto_smb configuration file, if missing if [[ ! -f /etc/auto_smb ]] then echo "$local_volume -fstype=smbfs,soft,noowners,nosuid,rw :$remotedest" >> /etc/auto_smb fi # add auto_smb to auto_master, if missing if [[ 0 -eq `grep -c auto_smb /etc/auto_master` ]] then echo "/- auto_smb -nosuid,noowners\\n" >> /etc/auto_master fi # add auto_tm to auto_master, if missing if [[ 0 -eq `grep -c auto_tm /etc/auto_master` ]] then echo "$sparsebundlemountpath auto_tm\\n" >> /etc/auto_master fi # make the auto_tm reconnect script, if missing if [[ ! -f /etc/auto_tm ]] then echo "#!/bin/bash \\n\\ set -xEe \\n\\ PHYSICAL_DRIVE_PATH='$local_volume' \\n\\ SPARSEBUNDLE_PATH='$sparsebundlefull' \\n\\ TIME_MACHINE_DESTINATION='$timemachinedestination' \\n\\ \\n\\ # Check existing states \\n\\ if [ -e \\"\\$TIME_MACHINE_DESTINATION\\" ]; then \\n\\ echo 'Already mounted.' \\n\\ exit 0 \\n\\ fi \\n\\ \\n\\ if [ ! -e \\"\\$PHYSICAL_DRIVE_PATH\\" ]; then \\n\\ echo 'Physical drive not attached' \\n\\ exit 1 \\n\\ fi \\n\\ cd \\"\\$PHYSICAL_DRIVE_PATH\\" \\n\\ \\n\\ if [ ! -e \\"\\$SPARSEBUNDLE_PATH\\" ]; then \\n\\ echo 'Virtual drive not found on physical drive' \\n\\ exit 1 \\n\\ fi \\n\\ \\n\\ hdiutil attach -nobrowse \\"\\$SPARSEBUNDLE_PATH\\" \\n\\ " > /etc/auto_tm chmod +x /etc/auto_tm fi # enable browsing of mounts sed -e 's/^.*\\(AUTOMOUNTD_NOBROWSE=\\).*$/\\1FALSE/' /etc/autofs.conf > /etc/autofs.new mv /etc/autofs.new /etc/autofs.conf # manually connect to physical mount echo "Manually connecting to mount: $local_volume" mount -t smbfs $remotedest $local_volume # go into local physical volume cd $local_volume # create serialnum directory if missing if [ ! -e $local_volume/$serialnum ]; then echo "Creating $serialnum directory" mkdir $serialnum fi # create the sparsebundle if [ ! -e $local_volume/$sparsebundle ]; then hdiutil create -size $size -layout GPTSPUD -partitionType Apple_HFS -type SPARSEBUNDLE -fs "Journaled HFS+" -volname $sparsebundlevolumename $size fi if [ ! -e $sparsebundlefull ]; then echo "Copying $sparsebundle ... $sparsebundlefull" cd $serialnum cp -Rf ../$sparsebundle . fi # unmount if manually mounted if [[ ! 0 -eq `mount | grep -c $local_volume` ]] then echo "Unmounting manual mount $local_volume" umount -f $local_volume fi sleep 5 # restart autofs server, which will run: auto_master, auto_smb, auto_tm automount -cv #cd into TimeMachine dir to activate auto_tm script cd $local_volume du -hs $local_volume cd $sparsebundlemountpath du -hs $sparsebundlemountpath sleep 20 # setup crontab for volume poke echo "#!/bin/bash \\n\\ \\n\\ cd $local_volume \\n\\ /usr/bin/du -hs $local_volume \\n\\ cd $sparsebundlemountpath \\n\\ /usr/bin/du -hs $sparsebundlemountpath \\n\\ sleep 20\\n\\ " > $touch_volumes_script_full_path chmod +x $touch_volumes_script_full_path touch /etc/crontab echo "30 * * * * $touch_volumes_script_full_path > /Users/admin/crontab.out 2>&1" > /tmp/2112 crontab < /tmp/2112 # attach to the sparse bundle if [ ! -e $timemachinedestination ]; then echo "Attaching $sparsebundlefull ..." hdiutil attach -nobrowse $sparsebundlefull fi # make time machine run faster sysctl debug.lowpri_throttle_enabled=0 # set time machine destination echo "Setting time machine destination" tmutil setdestination $timemachinedestination # enable time machine backups echo "Enabling time maching ..." tmutil enable # start initial backup echo "Start initial backup -auto ..." tmutil startbackup --auto
jamf-42
  • Nov 14, 2022 5:18 PM UTC
Its been a while, but I'm sure TimeMachine doesn't support RAID.. just in case what-ever is on the end of the SMB is setup that way.. (this may have changed, but you know data and all that) ..try pulling a disk.. that'll test it! 🤣
  • Nov 15, 2022 2:15 PM UTC
Also note that this script can be modified for SMB mounting Auto mount, without the Time Machine features.
If you need a persistant SMB share mounted ,
Side note: AutoFS, has a feature called "executable maps" which when the mount point is activated runs a script file. That is how we auto mounted the sparsebundle file for TimeMachine. its a cool feature.
