Hi
was wondering if anyone could help out with this
I'm using a VPN script that Cem created which works a treat, but I find when I try deploying the script either at imaging time, casper remote or via Policies that it fails
Here is what I'm getting
/usr/sbin/jamf is version 8.22
Executing Policy 2012-01-04 at 1:40 PM | administrator | 1 Computer...
Mounting afp://buildbox-lon3.imagination.com/CasperShare to /Volumes/CasperShare...
Installing Imagination VPN.dmg...
Closing package...
Running Script hong_kong_vpn.sh...
Script Exit Code:0
Script Result: Variable "vpnFilePath" value is set to: /Applications/Utilities/Hong Kong VPN.networkConnect
Assistive Device Access is already enabled.
Importing Network Adapter...
Renaming the VPN interface to Hong Kong VPN...
The following network adapters are present after the import:
An asterisk () denotes that a network service is disabled.
Bluetooth DUN
Ethernet
AirPort
Hong Kong VPN
Running Script london_vpn.sh...
Script Exit Code:0
Script Result: Variable "vpnFilePath" value is set to: /Applications/Utilities/London VPN.networkConnect
LSOpenURLsWithRole() failed with error -10810 for the file /Applications/Utilities/London VPN.networkConnect.
Renaming the VPN interface to London VPN...
VPN (IPSec) is not a recognized network service.
VPN (IPSec) is not a valid network service name.
** Error: The parameters were not valid.
Bluetooth DUN
Ethernet
AirPort
Hong Kong VPN
London VPN is not a recognized network service.
Running Script nyc_vpn.sh...
Script Exit Code:0
Script Result: Variable "vpnFilePath" value is set to: /Applications/Utilities/NYC VPN.networkConnect
LSOpenURLsWithRole() failed with error -10810 for the file /Applications/Utilities/NYC VPN.networkConnect.
Renaming the VPN interface to NYC VPN...
An asterisk (*) denotes that a network service is disabled.
Bluetooth DUN
Ethernet
AirPort
Hong Kong VPN
NYC VPN is not a recognized network service.
Unmounting file server...
