SelfService not working on some clients
carlo_anselmi
Contributor III
Hello,
Is there a way (logs, etc) to understand/troubleshoot why SelfService does
not work with only some client?
If I login to SS using the same user and run any of the available policies
that works with other clients, almost nothing happens.
I can only briefly see "loading data from server" and the progress bar
immediately reaches the end (without running any policy) then everything
stops.
Many thanks for your help
Ciao
Carlo
2 REPLIES 2
dderusha
Contributor
Check the policy and make sure you attached a package, script or printer
etc.
Dan De Rusha
carlo_anselmi
Contributor III
Thank you, Just found out it was clients fault.
Re-added them on the JSS and issue solved-
Cheers
Carlo
