I am attempting to set a custom desktop background for all users through Configuration Profiles, and it is working. However, it is locking the desktop backgrounds, and I am unable to change it once it is set. There is an option in the Configuration Profile to lock the desktop background, and I do not have it selected, but it seems to be locking it anyway. Users need to be able to change the background after it is set.
I am deploying the background image into a folder in the root directory, and simply setting the background to it using a configuration profile. Is there a better way to do this? Any ideas on why it is locked, when that option isn't selected? The only way I've been able to change the desktop background is to remove the configuration profile from the computer, then reimage it completely.
