Setting innodb values in my.cnf Ubuntu 18.04
honestpuck
Installing JPS onto an Ubuntu 18.04 VM.
I have found /etc/mysql/mysql.cnf but it only contains two include lines.
I added
innodb_buffer_pool_size=5500M
innodb_file_per_table=1
At the point mysql refused to start. Removing the lines allowed it to start again.
Suggestions?
Best answer by ryan_ball
@honestpuck The file you want is /etc/mysql/mysql.conf.d/mysqld.cnf on 18.04.
Remove it from what you used initially and add it there.
I commented about this in the following article:
https://www.jamf.com/jamf-nation/articles/542/creating-the-jamf-pro-database
Jamf should update the article or at least note this.
  • 389 replies
  • January 8, 2019
are you sure that's the correct file??
I use RedHat and my file is located at /etc/my.cnf
possibly try searching for my.cnf as opposed to mysql.cnf?
  • 475 replies
  • January 8, 2019
honestpuck
  • 48 replies
  • January 8, 2019
@ryan.ball They definitely need to update the article. I might raise it somewhere.
Cookie policy
Cookie settings
