Sierra Constantly Prompting for Cert Verification
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 12-15-2016 02:02 PM
Hey Guys,
Weird issue here. I'm seeing the issue described here in my environment: https://m.reddit.com/r/sysadmin/comments/52mz6r/apple_sierra_breaks_ssl_w_blank_subject/
Basically, when you connect a Sierra mac to the corporate WPA Enterprsie WiFi, Sierra will always request for you to validate the certificate, even after marking the cert as "Always Trusted." On first connection it gives an error: "This certificate is not valid (empty subject name)" It's an X509 cert.
Subsequent times it doesn't give that error, but always pushes a pop up to verify the certificate. This didn't happen in El Capitan, and I've tried setting up the network connection manually and still get the same outcome.
(I'm on the latest patch of Sierra as well, just to make sure)
Is anyone else seeing this? Anyone found a way to not get the pop up every single time you connect to WiFi?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-15-2016 08:25 PM
Hi @bsanto
Just a quick thought, is your time / date / location correct?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-16-2016 07:53 AM
So far as I know. Good thing to check regardless. I'll let you know.
Edit: Yup, date/time/location are all correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-05-2017 11:49 AM
Followup:
I ended up changing the certificate that the RADIUS server was using in the Windows Network Policy Service. When I changed it to a different cert that also identifies the RADIUS server, everything works as expected now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-13-2017 03:29 PM
Hey bsanto!
Could you elaborate on your fix, please? We can't tell where an X509 cert is getting pushed from in NPS; but we are experiencing the same issue you've outlined. Any help would be appreciated.
