Smart group membership based on extension attribute data
rpayne
Contributor II
During our deployment we utilize jamf connect for account creation and for password sync thereafter. We don't use connect for login AFTER deployment (we have a policy in DEPnotify that resets authchanger). All is well and good until a macOS update comes along and machines revert authchanger to jamf connect. We have contacted jamf and were told it's a product issue.
Now, to fix the issue so it doesn't keep happening. The idea is to place a dummy file on machines DURING enrollment with an extension attribute to verify the file's existence (report a value of true or false) and pull the configuration profile for jamf connect login (excluding a smart group with membership based on extension attribute data). The file/policy is done. The extension attribute is done and reporting correctly.  The issue is I can't figure out how to scope a smart group based on the given data.
Has anyone done this? Is it possible? Is there a better way to do it?
1 REPLY 1
rpayne
Contributor II
Figured it out RIGHT after posting this.
