Smart groups based on user groups using SAML/SSO
  • August 22, 2018
  • 3 views
Hello,
We're using SAML for SSO and I'm trying to make a smart group for the members of particular groups but the problem is within JAMF it says "0 members" for each group. How do you make a smart group for users to build policies based using SAML for SSO?
1 reply
I, too, would like this feature but unfortunately it isn't a supported feature. If you want to scope and use SSO/SAML, you'll need to manually create your users and groups via the JPS. If you do go this route, make sure your usernames match the SSO username or you'll run into issues down the line.
