Posted on 04-22-2022 12:09 AM
I'm trying to put together a Smart Group that contains Computers if either 1 of 2 applications is missing.
Currently I'm using
Application Title - does not have - "App1" OR Application Title - does not have - "App2"
I have computers listed that have App1 installed. I know there are other computers that have App1 installed so I can't work out why only some computers are present.
Posted on 04-22-2022 05:51 AM
Try using the parenthesis to separate the criteria. Since you're needing either one to be true, you actually need to evaluate two data sets, if you will. I mocked this up really quick using Chrome and Edge as the criteria. I first had only Chrome installed and the machine was in there. Once I installed Edge, the computer fell out. I then deleted Chrome and the computer came back.
