- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 06-07-2016 10:06 AM
So we recently deployed Snagit to our users per their request. It's been a couple months now and things are going good, until today. I got a request to enable the Scrolling capture. Because this seems like a potential security risk, I'm working with our security team to check it out. But the other issue is our users don't have admin access, so even if we did allow it - we need a way to activate it via script.
So I started by using my admin credentials and activating it on my laptop. I know the accessbilty stuff goes into the TCC.db. So I saw that it added two things into the accesbilty table when I did it manually:
kTCCServiceAccessibility|com.TechSmith.Snagit|0|1|1|
kTCCServiceAccessibility|com.techsmith.snagit.capturehelper|0|1|1|
So I wrote a script that pretty much does that, but got into issue. Here's the quick script:
sudo sqlite3 /Library/Application Support/com.apple.TCC/TCC.db "INSERT or REPLACE INTO access VALUES('kTCCServiceAccessibility','com.TechSmith.Snagit',0,1,1,NULL)"
sudo sqlite3 /Library/Application Support/com.apple.TCC/TCC.db "INSERT or REPLACE INTO access VALUES('kTCCServiceAccessibility','com.techsmith.snagit.capturehelper’,0,1,1,NULL)"
sudo sqlite3 /Library/Application Support/com.apple.TCC/TCC.db "select * from "access""
The last command just lists all the access so I can check it was done correctly. The reason I put that there is because the com.techsmith.snagit.capturehelper doesn't appear to work on a fresh machine. When the script is run on a machine with a fresh install of snagit it gets:
ERROR: unrecognized token "'com.techsmith.snagit.capturehelper',0,1,1,NULL)"
So has anyone been able to package it with the ability to enable scrolling capture?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-07-2016 12:08 PM
I drop a copy of tccutil.py on our managed Macs, and then just run /path/to/tccutil.py -i com.TechSmith.Snagit
and /path/to/tccutil.py -i com.techsmith.snagit.capturehelper
after installing Snagit.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-07-2016 12:40 PM
Will check it out - thanks!
UPDATE: worked like a charm.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-09-2017 12:18 PM
Hi @bvrooman does it still work for you on 10.13?
I get the following error:
Traceback (most recent call last):
File "/usr/local/bin/tccutil.py", line 294, in <module>
main()
File "/usr/local/bin/tccutil.py", line 281, in main
insert_client(item)
File "/usr/local/bin/tccutil.py", line 212, in insert_client
c.execute("INSERT or REPLACE INTO access VALUES('kTCCServiceAccessibility','%s',%s,1,1,NULL,NULL)" % (client, client_type))
***sqlite3.OperationalError: attempt to write a readonly database
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-31-2017 07:14 AM
@cindySingh No, Apple moved TCC.db under SIP with macOS Sierra, so that carries through to High Sierra. Unfortunately, I haven't found a non-GUI way to accomplish the task in a current OS.
