Posted on 04-30-2008 02:55 PM
Anyone using SAV Symantec Anti Virus corporate version
We are using Symantec Administration Console for Macintosh and it is a pain.
Does anyone have a way to Kill it and use Casper to insure clients are up to
date.
Thanks
Ricky
Posted on 04-30-2008 02:59 PM
No automated method however you can pull sav PKG av updates from here
ftp://ftp.symantec.com/public/english_us_canada/products/norton_antivirus_ma
c/antivirus_definitions and push them using Casper.. Messy but will work
Posted on 05-01-2008 07:41 AM
First, make sure you're using version 1.0.2 of the SACM and 1.0.3 of the
SACM client installer. It comes with the corporate edition of SAV 10.2 and
fixes a lot of problems.
I prefer not to use the SACM for pushing updates. I want to see more
immediate results. Instead I have an ongoing policy in Casper to tell all
Macs to update themselves to our internal LiveUpdate server daily and I have
the same policy command in a saved ARD Send Unix command so that I can
manually update a machine. That command is:
/Applications/Symantec Solutions/LiveUpdate.app/Contents/MacOS/LiveUpdate
-update LUal -liveupdatequiet YES -liveupdateautoquit YES
For us the SACM is better used as a monitoring tool although we do send out
commands with it for some things.
bill
William M. Smith, Technical Analyst
Digital Information Systems Support
Merrill Communications, LLC
(651) 632-1492
Posted on 01-07-2013 08:55 AM
HI, has any one have problems with the inventory for a workstation , showing the definition date are not upto date but , when you check the workstation the symantec definitions are up to date ,
Posted on 01-07-2013 01:21 PM
Hi Emmanuel, is the workstation reporting properly?
