Posted on
11-16-2018
09:20 AM
- last edited on
03-04-2025
06:20 AM
by
kh-richa_mig
I ran the installer and broke Office 16. Fortunately, it is just my system and I am not ready to update. Does anyone have a script or a tip to remove this? I have searched for HELP and deleted the files references in the script. Apparently the Microsoft Office setUp Assistant is also the issue.
Posted on 11-16-2018 01:25 PM
There might be a tool here: https://macadmins.software/tools/ that may help you
Posted on 11-16-2018 02:39 PM
Quit all Office applications and then remove /Library/Preferences/com.microsoft.office.licensingV2.plist (I believe that's the correct plist name. If not, it's very similar.)
You can then run the VL Serializer for Office 2016 and that should reactivate your Office 2016 applications.
Posted on 11-19-2018 07:31 AM
if you want to remove the license (all) use this tool
and run this.
After this the Office is unlicensed again and you can either license via O365 or run a Volume licenser again.
