We use startup scripts set to be available offline. Once the systems are enrolled they will not connect except via a vpn client on the guest. Testing has confirmed that casper does not look for updated policies when it checks in with the server unless it is time for that policy to run. I tried running "sudo jamf policy -id ##" which ran the updated script, however it STILL didn't update the locally cached copy...
Does anyone know a way to force Casper to update ALL locally cached policies when it checks in with the server??
