Hello everyone,
Very much a newbie question, but I'm looking to see if anyone has any luck with configuring settings within Java's control panel. The process of upgrading Java, I've found, is by simply dropping the .pkg into CA. However, does anyone have a best suggestion for configuring settings:
Specifically disabling
- Use SSL 2.0 compatible ClientHello Format
- Use TLS 1.1
- Use TLS 1.2
