Posted on 08-14-2008 02:37 PM
Hi all,
We have just upgraded to version 6.0 and now we cannot get Tomcat started. In the JSS setup utility it says that my Database Schema is 6.0, my SQL version is 5.0.45, and that my Tomcat version is unavailable . All other services are running fine and I have tried reinstalling JSS on the server to no avail.
Any ideas?
Ron Prue
1441 West Ute. Blvd Suite 100
Park City, UT 84098
435.214.2927
ron.prue at mynoahs.com
Posted on 08-14-2008 03:13 PM
what version of OS X and what type of install? Tomcat works great on my new JSS installed it last night and migrated to 6.0 no issues here. I did a clean load of 10.5 server and set it up as a stand alone advanced server.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
cell: 913-449-7589
office: 913-627-0351
Posted on 08-14-2008 03:16 PM
We are on Leopard 10.5.4 using it as an Open Directory Master.
Ron Prue
Park City, UT 84098
435.214.2927
Posted on 08-14-2008 03:17 PM
We had that same problem, call their support & they will walk you though
manually starting and also editing the config file. It's a very quick fix
and I'm sorry I can remember the exact thing I did or I'd share it here.
Hillary
Hillary Postman
Technology Support Specialist III
Capistrano Unified School District
33122 Valle Rd.
San Juan Capistrano, CA
(949) 234-5530
Posted on 08-14-2008 03:19 PM
I think when you run it on an ODM it modifies the tomcat launchd plist and you have to go in and modify that file to get it to work.
JAMF support should know the answer.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
cell: 913-449-7589
Posted on 08-14-2008 03:20 PM
I will contact support as you suggest. Thanks Hillary and Thomas.
Ron Prue
Park City, UT 84098
435.214.2927
