Using Casper PKI for EAP-TLS wireless authentication via FreeRadius?
  • May 28, 2015
  • 5 replies
  • 44 views
We're starting to look at authenticating our computers (and iOS devices) via EAP-TLS, which seems to require some kind of machine certificate. Anything I search for seems to be pointing to using an MS AD certificate server, but we're hoping to use the built in PKI server in Casper.
Our 802.1x authentication server will be FreeRadius.
Has anyone looked at this and can point me in the right direction?
Jeff
  • July 8, 2015
Hy,
Can one use the internal pki ca of the jss server and the generated computer certificats to be used in a 802.1x scenario. The mdm computer certificat should open the port o the switch (ethernet).
Is that possible and is someone having more info on how to setup that ?
JSS 9.7.2, Cisco Switches, 389 Directory Server
  • August 24, 2016
We would like to go into the same direction. Why setting up another PKI if Casper already has one?
Did you find any answers to your question yet?
Forum|alt.badge.img+23
  • August 25, 2016
Casper's PKI is not readily accessible in the way you need for this to work. You're better off running an MS CA server in an AD environment.
Is this still the case 5 years later? It seems odd that there is a built-in PKI that issues an identity certificate that you cannot utilize.
  • January 11, 2021
Jamf's internal CA is meant for device trust to Jamf only. It's not meant for individual users. That's why you need something like an AD CA or something that can utilise an IdP for the same purpose.
