Using InTune with Zscaler
  • September 17, 2018
  • 2 views
Stevie
Has anyone been able to get Microsoft InTune working with Zscaler or a proxy server? We have found that when Zscaler is enabled, the Jamf AAD never launches after the Company Portal has finished registering the device with the Azure portal. If we quit Zscaler and repeat the process the second login window is generated by Jamf AAD and the device is then fully enrolled into Intune.
I have passed a packet trace of the issue onto Zscaler for both setups. They have suggested a few SSL bypass setting for some Microsoft domains but as yet, they have been unable to solve the issue.
What SSL bypass rules have other people used on their firewall or proxy servers? Maybe everyone could post their setting for other people to use.
Zscaler have told us to enter the following SSL exemptions
.helpshift.com
.microsoft.com
.microsoftonline.com
login.windows.net
.microsoftonline-p.com
.jamfcloud.com
1 reply
  • 26 replies
  • October 30, 2020
We have InTune registration working with Zscaler enabled. Couldn't tell you our settings but was pretty frictionless - Didn't have to make any specific exceptions.
Cookie policy
Cookie settings
