Using JSON Header Authentication with Webhooks for Splunk
I've been trying to set up a Webhook to send data to Splunk.  We have a token to authenticate and when we set the authentication type to Header, we have to fill in the data in JSON format.  Nothing we've tried will successfully authenticate.  On the other hand, when I use a curl statement from the command line and authenticate in the header with the token without using JSON, it works just fine.
Has anyone had any success authenticating to Splunk with a token in a Webhooks using Header Authentication?
Be the first to reply!
Cookie policy
Cookie settings
