Hello,
I'm wanting to run a script which does different things based on the computers Building and/or Department.
For example, I use Munki also for managing specific apps that are a lot easier to deploy and update using Munki than they are using Jamf (sorry Jamf)... As a result, I would like to run a script on the concept of "If Department = Audio then set Munki Manifest to Audio"
Yes, I know I could simply write a script to set the manifest to Audio and only scope it to Audio Department, but I'd have to create an individual script for each department, then create a policy for each script and scope them accordingly - This is time consuming and adds clutter so would like one policy that runs on all computers, and I scope it to all departments so this would be much easier.
