Hello !
I made a smartgroup for macOS greater or equal to 15 Sequoia. It should be simple:
Criteria: Operating System
Operator: matches regex
Value: ^1[5-9]
I have NO computer running Sequoia, but I have 3 results. 3 Intel computers with macOS version 10.14.6 (2 of them) and 10.15.7 for the last one.
I searched all around and can't find where is the problem. I'm not really used with regex, but this one should be simple.
Any help is welcome
Wrong result with a smartgroup using a regex
Best answer by karthikeyan_mac
Hi @Spillou,
Any specific reason you wanted to use regex? We use criteria Operating System Version greater than or equal to 15 and it works.
The wrong results can be a bug. I used the regex as yours and notice there are few macOS 10.15.7 devices included in the scope.
Thanks
