How to update to Safari?
  • October 3, 2023
  • 14 replies
  • 471 views
mfletch
How are you updating your users to the latest version of Safari (17)? Mac Apps does not have Safari available and you can't add Safari to VPP, so I tried creating a package using composer and adding it to a Patch Management policy and pushing it that way, but that is not working. I also tried just creating a regular Jamf policy and adding the package there and pushing it out, but no dice even though the logs show it was installed successfully, but when the machine runs recon it still shows the old version of Safari, not Safari 17. I have Software Updates (System Settings>General>Software Updates) disabled because Restricted Software was not restricting users from going to macOS Sonoma, so this may have something to do with why I'm not able to update these devices to the latest version of Safari, but at this point It's just a guess.  Any help is greatly appreciated!
Best answer by Ashok_A
@mfletch - you may try the below simple code by executing on recurring check-in weekly once on all computers. This is how we keep our Safari Browser up-to-date.
#!/bin/sh Check_SafariUpdate=$(sudo softwareupdate -l | grep Safari | grep -o 'Safari[^[:blank:]]*' | head -n 1) /bin/echo "$Check_SafariUpdate" sudo softwareupdate -i "$Check_SafariUpdate"
jamf-42
  • October 3, 2023
download from here: https://mrmacintosh.com/macos-safari-full-installer-database-download-directly-from-apple/
And use Patch Management
If you look at the PKG its not a normal package (check it with Suspicious pkg) lots of perl scripts etc.. its not a normal pkg installer.. thus you can't just pkg it up..
AJPinto
  • October 3, 2023
Safari for N-1 (Currently Ventura) and N-2 (Currently Monterey) MacOS builds can be downloaded from Apple, its provided as a package. For the Current build of macOS (Currently Sonoma), Safari can only be installed with OS updates. You cannot package Safari and deploy it manually. Safari is not an Appstore app, and would not be deployed with VPP.
Do check your software update deferrals. You may have nonsoftware updates deferred. If nothing is deferred, make sure nothing is filtering Apple traffic as that will also prevent updates from working.
Solved: Safari 17 for Ventura - Jamf Nation Community - 300193
mfletch
  • October 3, 2023
@jamf-42  @AJPinto  Thank you very much for the information! I've downloaded the package and have it in the Patch Management definition and scoped and now I wait and hope it works! :)
jamf-42
  • October 3, 2023
scope small, test, check it works.. then move to production..
Ashok_A
  • October 3, 2023
mfletch
  • October 4, 2023
@Ashok_A Thank you, that worked great!
  • December 1, 2023
@AJPinto, this worked for us. Thank you!
  • December 1, 2023
@jamf-42, Thank you!
rpayne
  • March 12, 2025
How is everyone updating in Sequoia? The above script always returns: "No such updates." Updating the OS is the only way we've been able to update Safari. Are they not available separately anymore? Assuming this is the case as softwareupdate --list doesn't not return Safari updates (only MacOS updates).
mfletch
  • March 12, 2025
Yeah, only way I know of to update Safari is to update macOS.
jamf-42
  • March 12, 2025
this is  two year old thread.. times have moved on! For any device on 15.x your  only option is via software update, be that DDM scheduled via JAMF or something like Nudge. The Safari pkg is only available to older OS versions..
rpayne
  • March 12, 2025
Nudge is what we use usually. I just HATE moving update cycles so close. Users get upset. Well... more than usual.
jamf-42
  • March 12, 2025
and expect 15.4 soon..next week or the week after.. 🙄 maybe April.. but sooner that we'd all like. The only positive is in testing on ARM post download it took less that 10mins to install..
rpayne
  • March 12, 2025
Yup. I might just wait until 15.4. Thanks Apple. 😂
