error executing command
Forum|alt.badge.img+20
i took a look at a jamf.log on an enrolled mac and constantly see a line that says 'ERROR EXECUTING COMMAND' after a policy runs. What is happening or what is JAMF doing, what command is it trying to run?
seems to happen after every policy is run. The policy runs successfully but don't understand the 'ERROR EXECUTING COMMAND'.
here is a sample
Error executing command: ( "/Library/Application Support/JAMF/tmp/D95EA33D-BA13-442B-8304-AA9FD151B260"
daniel_ross
  • 190 replies
  • February 19, 2022
Hate to bump an old thread but did you ever figure this out?
  • 981 replies
  • February 19, 2022
@daniel_ross no one ever responded with an idea of what the issue could be.
I'll take a look again in the jamf.logs to see if the error still occurs.  I haven't looked in awhile since it seemes to not be an issue.
Are you getting,  seeing the same error?
daniel_ross
  • 190 replies
  • March 17, 2022
Your post hit the top of Google Search results when we were searching for something identical to this we have been seeing but its random and not always consistent.  I'll let you know when and how it happens again.  We have a machine in our Sandbox that we'll run through each item one at a time to see what happens.
  • 59 replies
  • March 22, 2022
Huh... I am seeing similar errors in my logs too:
jamf[9629]: Error executing command: (
"/Library/Application Support/JAMF/tmp/F4E1FF32-419B-43D9-BCB5-5C5CF63F97E6"
jamf[10875]: Error executing command: (
"/Library/Application Support/JAMF/tmp/B7C6137E-4403-4EE7-B268-47AA9D7DA61E"
jonw
  • 67 replies
  • April 4, 2022
Anyone get to the bottom of this?  I'm just noticing it on a few workstations (possibly M1 related?).
Despite the logged error, the policy appears to complete, I don't receive a typical 'policy failed' notification, and the tmp directory is empty.  Maybe just a Jamf bug?
  • 981 replies
  • April 5, 2022
@jonw @nberanger @daniel_ross
I haven't checked in a while but I'll check tomorrow.  More than likely it's probably still happening.  It doesn't seem to be an issue but it would be great to know what the error is
  • 981 replies
  • April 5, 2022
@jonw @nberanger @daniel_ross   Yep, i just checked my jamf.log and no matter what policy runs there is always that ERROR EXECUTING COMMAND : ****************** afterwards
  • 59 replies
  • April 5, 2022
This may be a coincidence but I've removed EAs and policies that were calling on Python. Since doing that, I am not seeing the errors showing in my log anymore.
jonw
  • 67 replies
  • April 6, 2022
 @daniel_ross @tcandela I think @nberanger nailed it (at least in my situation)!
I found a lingering Python script in an EA that I somehow missed when prepping for macOS 12.  Removed it and all is well again.  Many thanks for the reminder!
  • 59 replies
  • April 6, 2022
Should have added, this script was super helpful in cleaning up Python from our Jamf environment:
https://github.com/laurentpertois/Search-Scripts-In-Jamf/blob/main/searchScriptsAndEAsInJamf.sh
  • 101 replies
  • April 25, 2022
Hi All!
I was having the same error and my Macs were not completing recon commands due to the EA I had running that checked for the version of Chrome and reported Current or Old. It was written in Python and when recon ran it generated the same error in the logs: https://github.com/hjuutilainen/adminscripts/blob/master/chrome-enable-autoupdates.py I have changed the EA to this and recon commands are completing again and it has solved a ton of seemingly random issues for me.
if [ ! -f "/Applications/Google Chrome.app/Contents/Info.plist" ] ; then
echo "<result>Chrome isn't installed</result>"
INSTALLEDVERSION=$( defaults read "/Applications/Google Chrome.app/Contents/Info.plist" CFBundleShortVersionString )
CURRENTVERSION=$( curl -s https://omahaproxy.appspot.com/history | awk -F',' '/mac,stable/{print $3; exit}' )
if [[ "$INSTALLEDVERSION" == "$CURRENTVERSION" ]]; then
echo "<result>latest - $CURRENTVERSION</result>"
echo "<result>old</result>"
Cookie policy
Cookie settings
