Is Jamf Connect required for AzureAD Auth?
  • April 1, 2023
  • 7 views
We are using Jamf Pro and are setup as shared devices using Setup and Reset. and microsoft authenticator.
What is involved in switching over to user assigned still using reset for a device format and logging into a device with Azure creds?
Is Jamf connect required for this?
I am trying to achieve a shared device that users make their own for their shift and reset and wipe at the end, during their shift they can use outlook/teams/word/onedrive etc with app protection policies and conditional access.
1 reply
SteveS
  • August 21, 2023
Did you get your questions answered? Connect isnt required and we dont use it.
