We've recently started testing Jamf Connect and Azure IdP and was wondering about the following.
1. It seems password sync only occurs when using the menu app. If we change a users password and then login to the Mac we're not given the option to sync the password. Is this normal?
2. From the user perspective having the Azure login screen or the apple native login screen depending on the situation isn't very nice. Can Jamf Connect be setup to use Azure but with the apple native (Or close to) login screen just to try and maintain a consistent login process.
