Jamf Connect Stays Open when Selecting Connect
  • March 7, 2023
  • 0 replies
  • 7 views
DMH2000
I guess the subject says it all, Jamf Connect Stays Open when Selecting Connect.  After the latest update to 2.20.1 last month, it worked.  It just recently stopped working as it should (connect and close).  I also have seen this work as expected and not at times over the years, so don't know the mechanics behind it.  Has  anyone seen this or know why this happens? I can select change and reset password, and the Azure window opens and I can change or unlock it there. Company Portal is OK, as device shows enrolled with Jamf. (I don't think that has anything to do with the issue I have though).
Thanks for any info you can provide! 😀
