802.1X Wired Connections with Certificate
angryant
New Contributor III
Has anyone managed to get this working?  We have tried to set this up without any success.  We have added the required certificate to our Config Profile and I can see it on the machines in Keychain Access but our Network team say the devices are presenting the JSS Built in Certificate to the server instead of the certificate we have added in the Config Profile?
The certificate is trusted and we have the correct common name, but it doesn't appear to be being sent out from the mac.
Any suggestions appreciated.
4 REPLIES 4
sdagley
Esteemed Contributor II
@angryant Not to ask an obvious question, but the certificate payload is in the same Configuration Profile as your Network payload for your wired Ethernet network configuration, and that certificate is specified under the Network Security Settings for the Network payload?
angryant
New Contributor III
Yes they are both in the same Config Profile.
sdagley
Is it applied at Computer level? (Apple's MDM spec says only Computer level is supported for Wired Ethernet, but Jamf will allow you to deploy at User level)
angryant
New Contributor III
Hi Yes we have it spplied at the Computer Level.
