Posted on
05-29-2019
09:55 AM
- last edited on
03-04-2025
07:30 AM
by
kh-richa_mig
Hi-
When I first installed the JAMF Standard deployment on my Late-2013 Mac Book Pro running MacOS 10.14.5, there was the choice to select which Blueprint. I chose the Operations blueprint. I later chose the Management blueprint.
What I noticed was that the System Keychain had about 50 certificates in it which I had never seen before. Those Certificates are oddly no longer present. Is there a default setting on the Operations Blueprint which is not on the Management Blueprint which is preventing the deployment of those certificates?
Perhaps the chosen Blueprint isn't to blame. Is it possible there is some other setting to get the Certificates back into my Systems keychain?
Cheers,
Info Actuaire
