Posted on
12-01-2016
09:40 AM
- last edited
3 weeks ago
by
kh-richa_mig
Bonjour,
Est-il possible à partir du MDM de neutraliser l'Air Drop d'un groupe de tablettes pendant un temps donné puis le rétablir ensuite ?
Merci d'avance.
Posted on 12-01-2016 11:33 AM
Yes, you can absolutely do this, just not with jamf PRO.
The payload is called "DurationUntilRemoval" and is measured in seconds. It's a restrictions payload, and the device has to be Supervised to make it work with AirDrop restrictions. You can try it with Apple Configurator 2 and I know that Lightspeed have support for this.
Patrik
Posted on 12-04-2016 06:57 AM
Hi Patrik,
Thanks a lot for the answer.
I'm gonna try this and I'll give you the report...
